IAP 93 WPA SECURITY VULNERABILITY
  • 1.  IAP 93 WPA SECURITY VULNERABILITY
    Posted Oct 23, 2017 10:04 AM
    Hi all,
    Is there any release available for the last WPA vulnerabilities?
    Regards
    EF
  • 2.  RE: IAP 93 WPA SECURITY VULNERABILITY
    Posted Oct 23, 2017 04:32 PM
    Currently the following Instant patch releases have been made available to address the issue: 4.2.4.9, 4.3.1.6, 6.5.3.3, 6.5.4.2.
    However, IAP-93 is no longer supported after 4.1.1.
    A 4.1 patch is in the works and should be made available soon.
  • 3.  RE: IAP 93 WPA SECURITY VULNERABILITY
    Posted Oct 25, 2017 05:39 AM
    any ETA about that patch?
    We have 3 IAP93 and 1 IAP103 and the Automatic Check Version doesn't work: "No response from server"
  • 4.  RE: IAP 93 WPA SECURITY VULNERABILITY
    Posted Nov 14, 2017 02:44 PM
    Any news?
    Regards
  • 5.  RE: IAP 93 WPA SECURITY VULNERABILITY
    Posted Nov 14, 2017 05:42 PM
    Hi! Sorry for the delay! We have scheduled the update for the 21/11 . I ll write you when done.
    Thanks!
    Sent from my Wiko FEVER
  • 6.  RE: IAP 93 WPA SECURITY VULNERABILITY
    Posted Nov 21, 2017 02:59 PM
    I read  release notes of 6.4.2.6-4.1.3.5  and is valid for IAP93 and it solves:
    WPA2 Key Reinstallation Vulnerabilities - CVE-2017-13077, CVE-2017-13078, CVE-2017-13079, CVE-2017-
    13080, CVE-2017-13081, CVE-2017-13082, CVE-2017-13084, CVE-2017-13086, CVE-2017-13087, and
    CVE-2017-13088.
    So I´ll install it.
    Regards
  • 7.  RE: IAP 93 WPA SECURITY VULNERABILITY
    Posted Nov 29, 2017 08:41 AM
    has someone updated the IAP-93 to 6.4.2.6-4.1.3.5 ? I'm trying that, but the APs reboot for a "out of memory" error and the upgrade fails...
  • 8.  RE: IAP 93 WPA SECURITY VULNERABILITY
    Posted Nov 29, 2017 09:08 AM
    I did it with pur problem.
    EF
  • 9.  RE: IAP 93 WPA SECURITY VULNERABILITY
    Posted Dec 18, 2017 06:17 AM
    Resolved putting the only 103 as master.
    Regards
  • 10.  RE: IAP 93 WPA SECURITY VULNERABILITY
    Posted Dec 19, 2017 06:42 AM
    I also have the problem of 93 IAPs out of memory trying to update, and I was waiting to find someone else who were able to update them. I'll try tomorrow forcing an IAP-205 as master before the update.
