IAP 93H
  • 1.  IAP 93H
    Posted Jan 17, 2012 12:30 PM
    Hi
    Do you guys know if there is going to be an "Instant" version of AP93? If so, will it work in "bridge" mode.
    Thank you
  • 2.  RE: IAP 93H
    Posted Jan 17, 2012 01:19 PM
    Even if there was going to be an IAP-93H, Aruba Instant does not presently support bridge mode.
  • 3.  RE: IAP 93H
    Posted Jan 17, 2012 01:52 PM
    Can you please describe your specific use case?
    thanks,
    Shashi
  • 4.  RE: IAP 93H
    Posted Jan 17, 2012 03:32 PM
    We are currently answering to an RFP where access points and bridges (mostly APs) are required. The budget is quite tight, so we'll be going for IAPs, but we need to find a solution for the wireless bridges the customer has required.
    I know we could always go for cheaper wireless bridges (linksys or something like that), but it would be great if we could offer a single-vendor solution.
    Thanks!
  • 5.  RE: IAP 93H
    Posted Jan 17, 2012 07:59 PM
    If this is an issue of coverage between building, you may get buy with MESH and directional antennas.  If this is a check mark for bridging, the answer is no, IAPs do not support bridging.
    Hope that helps!
