IAP administrative access validating against TACACS+
  • 1.  IAP administrative access validating against TACACS+
    Posted Jul 26, 2012 03:08 AM
    Hi
    A customer of ours has asked us if Instant APs support TACACS+ for device administration. ¿Do you know anything about this?
    Regards
    Samuel
  • 2.  RE: IAP administrative access validating against TACACS+
    MVP
    Posted Oct 20, 2014 03:06 PM
    IAP supports TACACS administrative access in the most recent version. (I'm not sure about other versions). Configure the TACACS server under "Security". Make sure the IAP is enabled on the TACACS server side and a shared key is on both. One thing to note is that the TACACS requests come from the AP not the VC address, be sure to verify your logic (especially if using ClearPass).
