IAP and Aruba Central deployment
  • 1.  IAP and Aruba Central deployment
    Posted Feb 01, 2019 09:28 AM
    Hello everyone,
    I would like to be sure about something. When connecting an IAP (AP 303), is there something specific to configure on the IAP or other (DHCP option, DNS) to enable the discover of Aruba Central ?
    If I connect an IAP and add it in Central with the correct licence, is it enough ? Do I need to configure something on Activate ?
    Thanks in advance for your help !
  • 2.  RE: IAP and Aruba Central deployment
    Posted Feb 01, 2019 10:30 AM
    You don't need to configure anything from Activate.  Everything is done in central.  Please see step 3 here: http://help.central.arubanetworks.com/latest/documentation/online_help/content/public_cloud/get_started/typical_workflow.htm
