IAP and CPPM AirGroup with high CPU Utilization
  • 1.  IAP and CPPM AirGroup with high CPU Utilization
    Posted Dec 06, 2018 04:14 PM
    I'm trying to track down the cause of this issue and wondering if anyone else has seen anything similar. We're seeing CPU utlization maxed out on an IAP-205 that uses AirGroup.
    Background:
    Hospitality environment running Instant APs.
    We want to allow residents to use personal IoT devices (Chromecasts, FireSticks, Apple TVs, Smart Home Devices, etc.)
    Using ClearPass to register resident devices, and Enforcing AirGroup Registration on the IAP, so that Resident A cannot cast to Resident B's devices, and vice versa.
    What I'm seeing is occasional high CPU utilization. I belive it is causing clients to drop off.
    TFC-Test AP205-cd:1a# show cpu details
    Mem: 91052K used, 34712K free, 0K shrd, 0K buff, 27476K cached
    Load average: 2.65 2.73 2.78  (Status: S=sleeping R=running, W=waiting)
      PID USER     STATUS   RSS  PPID %CPU %MEM COMMAND
     2878 root     R       1812  2753 68.8  1.4 mdns
     2816 root     R        752  2753 25.2  0.5 syslogd
        5 root     SW         0     2  2.9  0.0 events/0
    10332 root     R <      384 10320  1.9  0.3 top
     2842 root     S N     3600  2753  0.9  2.8 sapd
    I also see some errors in logs related to MDNS, but not sure precisely what they mean. Same errors are repeating over and over tens of times per second.
    TFC-Test AP205-cd:1a# show log debug
    Dec  6 16:06:34  mdns[2878]: <121019> <ERRS> |AP TFC-Test AP205-cd:1a@10.15.73.64 mdns| |aaa| Received attribute with invalid length -2 in rc_avpair_gen
    Dec  6 16:06:34  mdns[2878]: <527003> <DBUG> |AP TFC-Test AP205-cd:1a@10.15.73.64 mdns|  CPPM mdns_cppm_handle_swarm_coa 1461 Successfully parsed all CPPM attributes using RADIUS library (librc)
    For reference, this is a proof of concept environment:
    One 205 IAP with one SSID. 9 clients all authenticating via mac caching on ClearPass.
    The above CLI output was taken with only two AirGroup services enabled (Googlecast and DIAL), and only 3 AirGroup servers online (Chromecast Ultra and Google Home Mini).
    Has anyone ran into this before?
  • 2.  RE: IAP and CPPM AirGroup with high CPU Utilization
    Posted Dec 06, 2018 04:27 PM
    I thought I should also add that it's running Instant 6.5.4.8
    All AirGroup users and servers are on same SSID and VLAN.
    Broadcast filtering: ARP
    Multicast transmission optimization: Enabled
    Dynamic multicast optimization: Enabled
    DMO threshold: 90%
