IAP and GRE
  • 1.  IAP and GRE
    Posted Dec 05, 2013 05:38 AM
    Hi all, can someone shed some light on this ?
    IAP 105 cluster, I want to use static vlan assignment for a number of SSID's.
    So trunk the relevant vlans to the VC, will need to do this on all IAP's as the VC may fail.
    When a client hits an ssid on a non VC ap does it GRE tunnel the traffic back to the VC as in a controller based solution ? ie do all clients ultimately need to hit the VC ?
  • 2.  RE: IAP and GRE
    Posted Dec 05, 2013 09:34 AM
    No!  The only time that the client's traffic will hit the VC is if:
    1. You are using Virtual controller assigned for IP addressing
    2. You are using IAP+VPN functionality on that VLAN
    If it's just a static VLAN ID(s), then yhe traffic is dropped off locally on the APs wired port.
