IAP and STP
  • 1.  IAP and STP
    Posted Sep 08, 2016 06:21 AM
    i have a particulare issue with a cloud of IAP and STP on the switch (hp).
    When stp is off all works fine, but whrn STP is enabled the election of master fails and the WiFi not works properly.
    There is not portfast enabled, and is not possible to enable it.
    There are not mesh AP.
    Which test i can perform?
    Exist some best practice?
    Regards
    Andrea Acampa
  • 2.  RE: IAP and STP
    Posted Jul 19, 2018 09:08 AM
    I am also having a similar issue.  Did you ever find a solution?
