last person joined: 11 hours ago
IAP Aruba and Meraki
This thread has been viewed 31 times
  • 1.  IAP Aruba and Meraki
    Posted Jun 02, 2021 05:28 PM
    Does anyone of you know if it is possible to work together an Aruba IAP 315 and AP Meraki from Central?
    Carlos Silva Hernandez
  • 2.  RE: IAP Aruba and Meraki
    MVP GURU
    Posted Jun 03, 2021 06:33 AM
    No. Central can not manage Cisco Meraki APs, and the two APs can not cluster together.
    Dustin Burns
    Senior Mobility and Access Engineer @WEI
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2021
  • 3.  RE: IAP Aruba and Meraki
    Posted Jun 03, 2021 09:45 AM
    This link indicates the Aruba Central supported devices (v2.5.3):
        https://help.central.arubanetworks.com/2.5.3/documentation/online_help/content/nms/overview/supported_devices.htm
    Henderson Iturralde
