IAP as DHCP server
  • 1.  IAP as DHCP server
    Posted May 17, 2016 12:33 PM
    Hi everyone,
    If IAP or Virtual Controller has network assigned  (static or dynamic) option  inside of SSID configuration,  could it be configured as DHCP server?
    I don´t know if it possible that and IAP (virtual controller) acting as DHCP server for several VLANs in which it doesn´t have  IP address because it only has IP address in the management VLAN.
    EF
  • 2.  RE: IAP as DHCP server
    Posted May 17, 2016 12:50 PM
    Something similar was asked here
    http://community.arubanetworks.com/t5/Aruba-Instant-Cloud-Wi-Fi/Simple-DHCP-question/m-p/266872#M14500
    Though I think you would need IAP to have an IP in each VLAN, so my guess would be not supported in your case.
