I was wondering is there an option to have an auto pop-up page in IAP captive portal after user has connected to guest SSID?
software: 6.4.4.8-4.2.4.2_56164
-Antti
Did you setup your SSID as "Captive Portal?" https://www.youtube.com/watch?v=LvK68t4dTGs&list=PL37Y-XxK6oanTV3821XpKHFVo3hGPW-56&index=18
Hi cjoseph,
Thanks for your reply.
Yes, that SSID is configured with a guest profile and it is using external captive portal.
There is no role based access. The access is unrestricted mode.
There is no way to have a popup page (most browsers block it anyways). Typically the external captive portal server redirects a user when they authenticate successfully.
