IAP autojoin mode how?
  • 1.  IAP autojoin mode how?
    Posted Mar 30, 2016 04:12 PM
    so my question is...
    how can I join an IAP to a cluster with no use cable...I mean using wireless
  • 2.  RE: IAP autojoin mode how?
    Posted Mar 30, 2016 04:14 PM
    You need to connect them wired at least once.
  • 3.  RE: IAP autojoin mode how?
    Posted Mar 30, 2016 04:27 PM
    And switch off extended ssid's. After once connected by wire, place the IAP in range of at least one other IAP and you get a mesh without further configuration !!
  • 4.  RE: IAP autojoin mode how?
    Posted Mar 31, 2016 11:48 AM
    hello mrzero...
    so I do that! but no work...
    1. first all aruba IAP connecto to the switch...then dhcp asiggned IP address to them
    2. delete Instant SSID, then created another..so all the IAP are connected to the new SSID
    3. disconnect IAPs excep the master from the switch, then turn on the other IAPs
    but not connect, so I need to do something more?
  • 5.  RE: IAP autojoin mode how?
    Posted Mar 31, 2016 12:08 PM
    What type of IAPs ?
    And what InstantOS are you using ?
    Sent from Outlook for iPhone
  • 6.  RE: IAP autojoin mode how?
    Posted Mar 31, 2016 12:12 PM
    IAP 225
    Version 6.4.2.6-4.1.1.6_50009
  • 7.  RE: IAP autojoin mode how?
    Posted Mar 31, 2016 12:14 PM
    Mesh is supported on 802.11ac APs on InstantOS 6.4.3.1-4.2 and up
  • 8.  RE: IAP autojoin mode how?
    Posted Mar 31, 2016 12:17 PM
    so is there way to connect via wireless the IAPS to the IAP Master Controller for this version of Aruba?
  • 9.  RE: IAP autojoin mode how?
    Posted Mar 31, 2016 12:20 PM
    Yes .
    Once you upgrade all your IAP to the required InstantOS to form a Mesh
  • 10.  RE: IAP autojoin mode how?
    Posted Mar 31, 2016 03:33 PM
    Thanks Man...It was solved...
    I was Upgraded the firmware and then make the mesh like charm!
