I am putting about 10 IAP 105's at a remote site. I want all my ssid's and roles and policies from the master and do not want to recreate them on the VC. Can I join the VC back to my master controller and get the settings from it or are they not ment for this type of setup.
thanks
The master controller cannot push WLAN setting to the IAP.
so i have to have 2 totally seperate managed envyroments even tho they have to be the same policeies ?
Hold on.
You do NOT have an Aruba Controller, just IAPS, right?
no i have 5 aruba contollers 1 master 4 slaves at 4 campuses. I have a small remote campus where I want to use 10 IAP's but would like to have my roles available to the IAP campus and not recreate them all on the local vc
You can make a tunnel from the IAP to the controller, but you cannout push configuration information from the controller to IAP. You can push configuration information to an IAP from Airwave, however.
