IAP boot commands
  • 1.  IAP boot commands
    Posted Apr 20, 2016 03:38 AM
    Hi I have noticed that the IAP-275 does not accept the APENV commands after interrupting the boot sequence. Is there any reason for this or is this by design.
  • 2.  RE: IAP boot commands
    Posted Apr 20, 2016 03:54 AM
    What are the exact commands you are trying to put in?
  • 3.  RE: IAP boot commands
    Posted Apr 20, 2016 09:46 AM
    Not exactly just any of them.
  • 4.  RE: IAP boot commands
    Posted Apr 20, 2016 10:27 AM
    You have to be specific
  • 5.  RE: IAP boot commands
    Posted Apr 20, 2016 10:29 AM
    Anybody know why the commands are not accepted?
  • 6.  RE: IAP boot commands
    Posted Apr 20, 2016 10:33 AM
    The commands work fine, I did it just last week on an IAP-275 with no issue. Are you sure you've loaded the correct driver for the USB within the 275? Getting specific output/console copies of what you are seeing would help.
  • 7.  RE: IAP boot commands
    Posted Apr 22, 2016 03:08 AM
    Thanks for the replies, the IAPs have booted up with the command set working now - I'm not sure what the problem was before.
