IAP Bridge
  • 1.  IAP Bridge
    Posted Feb 02, 2013 01:43 AM
    Is this setup a supported IAP design?
    Attachment(s)
    pdf
    setup.pdf   53 KB 1 version
  • 2.  RE: IAP Bridge
    Posted Feb 07, 2013 10:04 AM
    With normal campus AP's connected to a controller yes you can do that. But I believe that once you plug in the Eth port on an IAP it no longer looks for a mesh connection. So no I don't think that will work.
    If you find a way to do it with IAP's let me know.
  • 3.  RE: IAP Bridge
    Posted Feb 07, 2013 07:12 PM
    Yes LAN bridging is supported in IAPs.
    Enabling wired bridging on this port of the IAP makes the port available as a downlink wired bridge and allows client access via the port.
    go to page 90 on the latest IAP user guide.
