IAP Captive Portal
  • 1.  IAP Captive Portal
    Posted Mar 02, 2014 06:37 PM
    Is it possible to embed a link in the second box of the IAP Captive Portal?  If so can a user click on this link which would redirect them to the Terms and Conditions before hitting Accept?
  • 2.  RE: IAP Captive Portal
    Posted Mar 02, 2014 09:41 PM
    I figured it out, and then configured walled garden.
  • 3.  RE: IAP Captive Portal
    Posted Jun 26, 2019 04:43 PM
    I have tried this and it does not work. The preview gives the impression it works, but the commands are not saved to the configuration because it is a syntax error. (parse error to be exact). The reason for the parse error is Aruba uses quotation marks as delimiters for the text for the "Policy Text" value. The quotation marks in the < href=" ...> creates the problem in the configuration.
