IAP captive portal authentication against aruba controller via VPN connection
  • 1.  IAP captive portal authentication against aruba controller via VPN connection
    Posted Aug 05, 2013 10:32 AM
    I have configure VPN connection between Aruba controller and IAP. It works fine, but i'm looking a way for clients who are connected to IAP validate against he internal captive portal of my aruba controller.
    I tried to configure it using wired access control of the aruba controller (making vlan untrasted in only port who's active in controller), but it didn't work.
    Anyone have any idea about how can i do this?
    Thank you in advance
  • 2.  RE: IAP captive portal authentication against aruba controller via VPN connection
    Posted Aug 05, 2013 02:28 PM
    Can you provide us the output of
    " show user | in <IP of client> "
  • 3.  RE: IAP captive portal authentication against aruba controller via VPN connection
    Posted Aug 07, 2013 07:05 AM
    192.168.20.50  00:00:00:00:00:00  d8:c7:c8:c8:f0:5a  iNNI - guest-cp_prof  00:00:06    VPN     192.168.0.127  N/A        tunnel        Win 7
    I use rol iNNI-guest-cp_prof for captive portal authentication.
  • 4.  RE: IAP captive portal authentication against aruba controller via VPN connection
    Posted Aug 07, 2013 07:54 AM
    I assume,  the role  iNNI - guest-cp_prof has the captive portal ACLs. Then yes it should work. IF not, i request you to reach TAC.
