IAP captive portal with internal database
  • 1.  IAP captive portal with internal database
    Posted Jun 19, 2014 09:16 AM
    Hi everyone,
    I want to ask a question about instant AP with captive portal authentication.
    We created an SSID which has captive portal authentication with internal database.
    But we want that every username-password can use with only one active session.
    In controller structure, we can do that
    How can we do that with instant Aps? Is that possible?
  • 2.  RE: IAP captive portal with internal database
    Posted Jun 19, 2014 12:57 PM
    I don't this currently supported under the IAP setup, do you have ClearPass ?
  • 3.  RE: IAP captive portal with internal database
    Posted Jun 19, 2014 01:20 PM
    No, we dont have clearpass in our system.
    I thought maybe I can find a workaround for this. I also searched in the user-guide
    but it is interesting that why instant doesnot support this.
  • 4.  RE: IAP captive portal with internal database
    Posted Jun 19, 2014 01:59 PM
    I suggest you do a feature request.
