IAP Centralized L2 DHCP - Get IP but can't pass web traffic
  • 1.  IAP Centralized L2 DHCP - Get IP but can't pass web traffic
    Posted Sep 11, 2017 11:25 AM
    Some basics of our setup.
    - 2 x 3200 controllers in 2 different datacenters that RAPs and one office site use.
    - 7 other sites that use IAPs (mix of 105s, 225s and 325s) with their own virtual controllers per site.
    - A mix of a few SSIDs that are the same across all sites and use ClearPass.
    All of the above works flawlessly.
    What I am trying to do is setup an SSID with a centralized L2 DHCP that emulates a home network for testing. There are times we need to be able to act like we are working from home to test certain applications like Citrix etc.
    I have a completely separate internet link going through a separate firewall and router in our primary data center. I've set up the SSID and the centralized L2 DHCP scope in the virtual controllers. I have the correct VLAN assigned and it is in all switches across my entire network.
    I also have it setup in the 3200 controllers so that the RAPs and the one site that does not have instant APs can use it as well.
    What works: The RAPs and controller based APs have no problems and it works as needed.
    What does NOT work: In the instant APs I get a DHCP address, can resolve DNS and ping anywhere in the world, however I cannot pass HTTP/HTTPS traffic and open web pages.
    I am probably overlooking something in the virtual controllers, but cant seem to figure out what it is.
    Any help would be appreciated.
    Jeff
