I am receiving a warning certificate when guest users are trying to login to
You will need to upload a new certificate since the shipped certificate is not valid. Take a look at the below, this will give you further info.
https://community.arubanetworks.com/t5/Controller-less-WLANs/ArubaOS-Default-Certificate-Revocation-FAQ-Instant/ta-p/275814
If the message you are seeing is when Guest users are accessing the Captive Portal it will be a Captive portal server (PEM format) certificate that you require.
https://www.arubanetworks.com/techdocs/Instant_423_WebHelp/InstantWebHelp.htm#UG_files/Authentication/Certificates.htm
