IAP certificate upload
  • 1.  IAP certificate upload
    Posted Sep 23, 2016 05:39 AM
    Hi all I am trying to upload a certificate via the cli but i'm not sure of the format needed in th command - the user guide doesn't give me enough info, it stops after the TFTP address in the incomplete example.
    What I'm trying is something like -
    download-cert cp tftp://172.0.0.253/certificate.crt format pem psk passkey
    but its not working can anyone help with this please.
  • 2.  RE: IAP certificate upload
  • 3.  RE: IAP certificate upload
    Posted Oct 03, 2016 10:39 AM
    I don't need to generate a CSR as I already have the certificate, i want to upload it to the IAP.
  • 4.  RE: IAP certificate upload
    Posted Oct 03, 2016 10:41 AM
    Do you have the private key?
  • 5.  RE: IAP certificate upload
    Posted Oct 03, 2016 10:44 AM
    Yes I have the private key, the issue seems to be with this part of the command -
    I know there is nothing wrong with the key, passphrase or the cert its just the format of the command that it doesn't like.
  • 6.  RE: IAP certificate upload
    Posted Oct 27, 2016 03:26 AM
    Anybody know how this command needs to be structured?
