last person joined: 3 hours ago
IAP - Change Airwave ip now they are all showing as down
  • 1.  IAP - Change Airwave ip now they are all showing as down
    Posted Aug 21, 2014 09:23 AM
    I've just have to move and readdress a customers Airwave server.  Went into the IAP clusters and changed the ip address of Airwave, but they are all still showing as down.
    Short of deleting the group and then readding, is there anything else I should have to do here to make the IAP show as up?
  • 2.  RE: IAP - Change Airwave ip now they are all showing as down
    Posted Aug 21, 2014 10:06 AM
    Not sure if this is an IAP issue but have you tried rebooting the cluster as a fault isolation step?
  • 3.  RE: IAP - Change Airwave ip now they are all showing as down
    Posted Aug 21, 2014 10:21 AM
    the clusters are scattered around the world with varying production times, so I've not tried that.
    Might be easier to delete them, the group and everything else from Airwave, but was hoping to avoid having to do the heatmaps again.
  • 4.  RE: IAP - Change Airwave ip now they are all showing as down
    Posted Aug 21, 2014 10:22 AM
    Try the group change or opening up a case with TAC.
  • 5.  RE: IAP - Change Airwave ip now they are all showing as down
    Posted Aug 21, 2014 11:36 AM
    Was this change made before or after the AMP IP itself is changed?
    Sent from my iPhone
  • 6.  RE: IAP - Change Airwave ip now they are all showing as down
    Posted Aug 21, 2014 11:45 AM
    I changed the organisation string and this had no affect.
    A reboot on one of the clusters however has made them come up again on Airwave.
  • 7.  RE: IAP - Change Airwave ip now they are all showing as down
    Posted Sep 01, 2014 08:49 AM
    I've had issues with this before, resolved it by changing one of the characters in the virtual-controller key via CLI.
  • 8.  RE: IAP - Change Airwave ip now they are all showing as down
    Posted Sep 02, 2014 12:32 PM
    Interesting, I had a similar experience, and assumed that it was the fact that we have three folks adding clusters and figured that they miskeyed the key.
  • 9.  RE: IAP - Change Airwave ip now they are all showing as down
    Posted Sep 02, 2014 12:34 PM
    i'm referring to this key in the configuration.
    virtual-controller-key 160004ad011c10580117cc19b8f3cea59800b1dd615413f161
    Not the organization string
  • 10.  RE: IAP - Change Airwave ip now they are all showing as down
    Posted Sep 02, 2014 12:38 PM
    Me too.
    I had to go through many (not all) sites and change the key to get the communication to come up.
  • 11.  RE: IAP - Change Airwave ip now they are all showing as down
    Posted Sep 02, 2014 04:37 PM
    Strangely what I saw as well was that after Airwave came up, there was some info in the graphs for these IAP clusters, so it had obviously contacted them.
    When I changed the Airwave ip in the VCs, the info in the graph stopped from that point.
    In my case, changing the organisation made no difference, but it was the reboot that made them come back.  This may be due to an older version of code on the IAPs though.
  • 12.  RE: IAP - Change Airwave ip now they are all showing as down
    Posted Sep 03, 2014 08:02 AM
    What version of code were you running?
  • 13.  RE: IAP - Change Airwave ip now they are all showing as down
    Posted Sep 04, 2014 02:50 AM
    Airwave - 7.7.12
    IAP - 6.2.1.0-3.4.0.1
