IAP + ClearPass Self Registration / Captive Portal
  • 1.  IAP + ClearPass Self Registration / Captive Portal
    Posted Aug 07, 2019 01:17 AM
    I have a Clearpass server in version 6.8 in use.
    Since this server is not operated at my home, I address it via an external IP address.
    Connected there are two different IAP clusters, which I manage with Central.
    802.1x Authentication works without problems.
    However, the Captive Portal gives me a headache.
    -- The Captive Portal can be integrated into the SSID without any problems.
    -- The Self Registration or Authentication works without problems.
    -- After that I will be redirected to the "Register" or Login page again and again.
    I guess this is due to the following settings of the NAS server:
    -- I can adjust the NAS server at the normal Capitve Portal as well as at the Self Registration page. Here the login method is adjusted.
    Default is: Controller initialized.
    There is an item "IP address".
    By default it says "securelogin.arubanetworks.com" in it.
    As far as I know there should be the IP or name of the controller that is requesting.
    In my Integration Guide this is not adapted at all.
    Unfortunately I didn't find that much information...
    As I said: the IAP are in the LAN, the CPPM external, but reach each other.
    What is the best way to do this ?
    Or is there another possibility, another login method ?
    Best Regards
  • 2.  RE: IAP + ClearPass Self Registration / Captive Portal
    Posted Aug 08, 2019 04:50 AM
    I found out a workaround myself.
    1. I have configured "dynamic Address" under "Nas Vendor Settings"
    2. Everything else was left to default
    Instead of an Guest Application Service, you now need a radius service for the user authentication.
    There I set a filter based on SSIDs.
    Everything like auth, accounting works fine now.
  • 3.  RE: IAP + ClearPass Self Registration / Captive Portal
    Posted Nov 21, 2019 05:14 AM
    you are talking about a NAS server, do you mean the clearpass ?
    I don't know where to find the point -> dynamic Address" under "Nas Vendor Settings"
    Can you please assist ? rI am a rooky in clearpass
    Thank you
  • 4.  RE: IAP + ClearPass Self Registration / Captive Portal
    Posted Nov 21, 2019 05:32 AM
    you will find it here:
    ClearPass Guest --> Config --> Pages --> Self-Registrations
    --> <your Site> --> Edit
    In the right Corner --> "NAS Vendor Settings"
    To be honest, in the meantime I had a better experience with using named certificates on the instant cluster.
    One other possibility is, to use an already existing wildcard.
    If you use an existing wildcard you need:
    -- Wildcard cert (only DV, no EV)
    -- An DNS Alias
    In Clearpass you will configure these DNS Alias:
    captiveportal-login.yourdomain.com
    The Controller/Virtual Controller will listen so this default name (captiveportal-login) and hijack the Client Request :)
    Regards
