IAP & Client Match
  • 1.  IAP & Client Match
    Posted Feb 03, 2014 09:04 AM
    Does  IAP supports client match ?
  • 2.  RE: IAP & Client Match
    Posted Feb 03, 2014 09:33 AM
    Yes.  ClientMatch was introduced to the IAP platform with the 4.0.0.0 release.
  • 3.  RE: IAP & Client Match
    Posted Feb 03, 2014 11:19 PM
    After you upgrade to 4.0.0.0 release you will need to enable it. It is just a tick.
  • 4.  RE: IAP & Client Match
    Posted Feb 04, 2014 01:55 AM
    Thank you very much Normal Guy  and Marcus
