IAP client was associated to at initial authentication
  • 1.  IAP client was associated to at initial authentication
    Posted Jul 15, 2015 12:29 PM
    Is there a way to find which AP a client was on when it first authenticated in an Instant cluster?
  • 2.  RE: IAP client was associated to at initial authentication
    Posted Jul 15, 2015 02:01 PM
    Do you have AIrwave ?
  • 3.  RE: IAP client was associated to at initial authentication
    Posted Jul 15, 2015 02:06 PM
    I do have AirWave.
  • 4.  RE: IAP client was associated to at initial authentication
    Posted Jul 15, 2015 02:09 PM
    If you have the client mac address you should be able to search in Airwave and see association history of that client under client detail
