IAP cluster
  • 1.  IAP cluster
    Posted Feb 12, 2015 06:22 AM
    I have 6 ias 205. The problem is that a pc o another device connects to the iap master, it works, but if the iap isn`t the master, it doesn`t work. The configuration is the same for all, but they aren't sincronized.  :-( .
  • 2.  RE: IAP cluster
    Posted Feb 12, 2015 06:38 AM
    Do you see all of the IAPs in the Instant UI?
  • 3.  RE: IAP cluster
    Posted Feb 12, 2015 06:42 AM
    Yes yes, I see all of the IAPs in the Instant UI.
  • 4.  RE: IAP cluster
    Posted Feb 12, 2015 06:44 AM
    Check that all your instants units connected to the same VLAN/Switch port config.
    Check that all your instantap are from same region (US/IL/RW)
    Check that all your instant got the same AOS.
    Be sure that all your instants can "talk" each other - do simple icmp pings...
    Check that u see all your instants under the GUI of the VC(MASTER) (in the middle section of the screen)
  • 5.  RE: IAP cluster
    Posted Feb 12, 2015 07:12 AM
    [Check that all your instants units connected to the same VLAN/Switch port config.] --> OK
    [Check that all your instantap are from same region (US/IL/RW). !!!! The zone is blank (--)
    [Check that all your instant got the same AOS.] --> OK
    [Be sure that all your instants can "talk" each other - do simple icmp pings... ]--> OK
    [Check that u see all your instants under the GUI of the VC(MASTER) (in the middle section of the screen)] I think OK, the attached picture.
    Does the zone is necessary????
  • 6.  RE: IAP cluster
    Posted Feb 12, 2015 07:49 AM
    What type of authentication method are you using?
  • 7.  RE: IAP cluster
    Posted Feb 12, 2015 04:12 PM
    no,Region and Zone are diffrent settings , Zone is in order to split to groups your instant group.
    But you can see all your instants from the GUI.
    More info needed.
    *What happend when a client trying to connect the tested SSID from diffrent unit that isnt the master?(wpa2 aes / wep / 802.1x ?) what VLAN is your SSID is broadcasting? what is doing DHCP for that VLAN?
    Can u please copy your running config , and share it with us?
  • 8.  RE: IAP cluster
    Posted Feb 13, 2015 03:35 AM
    I reset the IAPs and began again the configuration. Now, it works. I think that I modified any parameter, maybe the virtual controller or other and then the iap goes crazy.  Now the configuration is correct and the syncronization is OK. Thank you all.
