IAP Cluster Limit
  • 1.  IAP Cluster Limit
    Posted Mar 18, 2014 11:00 PM
    Currently I have 52 IAP 104's and 5 IAP 135's in a single cluster running 6.3.1.2-4.0.0.3  and tried adding 9 more to it today.  Unfortunately this did not work around  and my cluster died, lost its VC or crashed, still trying to figure out what happened exactly. I lost connectivity around 59 AP's.
    My question is what is the limit of AP's I can put in a single cluster?  Also I have read that if I were to make one of the 135's the master it may handle this a little better?  Can you assign a 135 to be a preferred master?
    #AP135
  • 2.  RE: IAP Cluster Limit
    Posted Mar 18, 2014 11:09 PM
    There is something wrong... you should open a support ticket
    There is no limit on the cluster size...
    And yes its recommended that you put a AP 135 as Master of the cluster...
    Cheers
    Carlos
  • 3.  RE: IAP Cluster Limit
    Posted Mar 18, 2014 11:10 PM
    Correction; see below.
  • 4.  RE: IAP Cluster Limit
    Posted Mar 18, 2014 11:15 PM
    Really Clembo?
    Marcus told me that there was no limit... or at least thats what i understood... the only AP that got a hard liimit is the AP93
    You can elect the master or have preference with the preference enable here:
  • 5.  RE: IAP Cluster Limit
    Posted Mar 18, 2014 11:24 PM
    Not sure if work load takes into account but the cluster averages 400-600 users a day.  When I added the additional AP's the user count was around 510.
  • 6.  RE: IAP Cluster Limit
    Posted Mar 18, 2014 11:26 PM
    Well as far i know the suggested limit is up to 2000, the thing is that is not a hard limit... but is recommeded not going beyond that...
    I remenber i also read a post of marcus which said it was unlimited, im searching for it.
    Cheers
    Carlos
  • 7.  RE: IAP Cluster Limit
    Posted Mar 18, 2014 11:29 PM
    I am verifying this Carlos.   I always thought the same, but came across a doc that says otherwise.  I am confirming.   The article I am referring to can be seen on AFP:  https://afp.arubanetworks.com/afp/index.php/IAP-105#Limited_Scale.2C_Single-site_WLAN
  • 8.  RE: IAP Cluster Limit
    Posted Mar 18, 2014 11:32 PM
    Hello Chris!
    As far i remenber before he would tell me that the suggested limit was 64.  But then with the new firwmares the suggested limit was a bigger than that...
    Thanks for the document!
    Cheers
    Carlos
  • 9.  RE: IAP Cluster Limit
    Posted Mar 18, 2014 11:37 PM
    Yes, seems the information in that linked document is outdated/incorrect.    In fact, a fellow SE shared info on their 180 IAP-105 cluster at a hotel in Turkey.
  • 10.  RE: IAP Cluster Limit
    Posted Mar 18, 2014 11:39 PM
    180!
    thats a lot :)
    I guess then there must be something wrong and he should open a support case with the TAC....
    The cluster should have never crashed... unless its a bug or something?
    Cheeers
    Carlos
  • 11.  RE: IAP Cluster Limit
    Posted Mar 18, 2014 11:58 PM
    I have since created a second cluster just so I can provide connectivity to another area.  I think I will try the following tomorrow.
    1. Set preferred master to a 135 in original cluster.
    2. Clear the config in the temporary second cluster.
    3. Move the ports for the second cluster to the original cluster vlan.
    Question, if I clear the config under Maintenance what does that exactly do to the AP's in that cluster?  Set them back to instant SSID?
  • 12.  RE: IAP Cluster Limit
    Posted Mar 18, 2014 11:59 PM
    Yep it suppose to do that...it will bring it to factory default.
    Cheers
    Carlos
  • 13.  RE: IAP Cluster Limit
    Posted Mar 19, 2014 02:53 PM
    Does anyone have confirmation that I will be fine with this cluster size?
    In the end I will have 57 IAP 104's and 16 IAP 135's all in the same cluster.  I just want to confirm before I add any additional, I cannot have it go down like it did yesterday.
    Brandon
  • 14.  RE: IAP Cluster Limit
    Posted Mar 19, 2014 02:56 PM
    Well i would open a support case with that to see why this happened...
    Thats not a normal behavior, you even saw that Chris said that there was a client which got 180 IAP 105 in a turkey hotel...
    Cheers
    Carlos
  • 15.  RE: IAP Cluster Limit
    Posted Mar 19, 2014 03:11 PM
    I will call TAC.  Thanks to everyone for their input.
  • 16.  RE: IAP Cluster Limit
    Posted Mar 19, 2014 03:12 PM
    Good Luck!
