IAP Cluster Limits
  • 1.  IAP Cluster Limits
    Posted Feb 19, 2014 10:02 AM
    Hello all...
    I am aware of the 1024 device limit and 65 IAP per cluster limit, but what is the user experience for the 1025 device, does it just not connect?
    Randy
  • 2.  RE: IAP Cluster Limits
    Posted Feb 19, 2014 07:20 PM
    Hello! RBL!
    The limits are updated
    The suggested new limit with the new firmwares  its 2000 devices, which is not a hard limit...
    There isnt a limit as well on ap in a cluster but as far one of the SEs told me that he has seem 128 - 150 and more IAP
    Takae in mind that if you are gong to have soo many IAPs try using as master something like a IAP 225 or at least an IAP 135 which has better hardware...
     	   SDRAM memory	FLASH memory	CPU
    RAP-3WN(P)	128MB	16MB	AR9344 560MHz
    IAP-104/105	128MB	16MB	AR7161 680MHz
    IAP-114/115	256MB	32MB	AR9550 700MHz
    IAP-134/135	256MB	16MB	88F6560 1.6GHz Single Core
    IAP-224/225	512MB	32MB	P1020 800MHz Dual Core
     I copy you a table of the hardware of the IAPS.
    Guess if you are afraid of putting all in a cluster you can always do  L3 roaming between clusters.
    The limit of the IAP 93 is still there... so if you put one IAP 93 it will lock your cluster to 16 APS... and the limit of users i bealive with an iap 93 is still  256
    Hope that helps
    Cheers
    Carlos
  • 3.  RE: IAP Cluster Limits
    Posted Feb 20, 2014 09:28 AM
    Yes, it was very helpful information...thank you Carlos
    Randy
  • 4.  RE: IAP Cluster Limits
    Posted Jan 12, 2015 07:27 AM
    Is hti still so? I believe after the latest upgrade this limit was lifted up to 32 IAP, am I wrong? Thanks.
  • 5.  RE: IAP Cluster Limits
    Posted Jan 12, 2015 10:22 AM
    The latest best-practice recommendations for cluster sizes are:
    92/93: 16 APs and 256 users.  There is a hard limit on the AP count but not on the user count.
    All other platforms: 128APs and 2048 users, there is no hard limit on either
  • 6.  RE: IAP Cluster Limits
    Posted Jun 17, 2015 11:49 PM
    Hi all,
    Is there actually a link or official documentation on this? ____
  • 7.  RE: IAP Cluster Limits
    Posted Jun 17, 2015 11:52 PM
    Its on aruba instant user guide..
    This is a extract of 6.4.2.0 user guide
    The limits of the AP 93 are on an older user guide or a realease not but i remenber i did read it... i just dont remenber which one is.
    Cheers
    Carlos
