IAP Clusters with dedicated SSID for tunneled GUEST
  • 1.  IAP Clusters with dedicated SSID for tunneled GUEST
    Posted May 17, 2017 11:17 AM
    Hello everyone,
    I'm facing an misunderstanding how IAP VPN work.
    I have a multiple site topology (MPLS) with multiples IAP Clusters, all managed by Airwave (DC).
    I've deployed an employee SSID facing a ClearPass (DC) for 802.1x authentication.
    I'd like to deploy a guest SSID, encapsulates this SSID into a tunnel to a mobility controller (7005) located in DC.
    DHCP server would be a VM in the same guest-network (only present on DC).
    Guests would be managed by Clearpass Guest. (but that's another step)
    I've setup my controller just like many others posts on this forum.
    Added my m@c into my whitelist rap, allowed-all my iap branches etc.
    I've setup through my Airwave, a Aruba-GRE VPN type that points to my controller.
    I can see my IAP using 'show iap table'
    I can see my tunnels up using 'show crypto isakmp sa'
    Problem is ... what's next?
    As far I understand I would have to configure a new SSID (eg: 33), type Employee, static VLAN assignment and configure a DHCP Centralized Scope (L2) and assign VLAN 33.
    I tried doing that, and ... it doesn't work.
    Thing is I don't really know where I could check what's wrong.
    I tried connecting a new laptop on this guest network, 0 incoming packets.
    I keep those documents opened but still haven't figured it out how to make it work :
    - Aruba Instant VRD (2016)
    - ArubaOS User Guide
    - Aruba Instant User Guide
  • 2.  RE: IAP Clusters with dedicated SSID for tunneled GUEST
    Posted May 18, 2017 05:45 PM
    Well, it seems I needed time to write it down and see where it was faulty.
    VPN is established between VC/AP to my Mobility Controller (DC).
    I understood how to hook traffic into this tunnel.
    I'm getting closer to my goal.
    I tried to have an (employee type) corporate SSID, with 802.1x security, linked to ClearPass so that I can authenticate user&machine against AD.
    This part is pretty much 'easy', single VLAN assignment, clearpass server defined as radius servers. This is now working.
    Guest is still getting much more complicated.
    I would like to isolate guest network.
    A dedicated SSID, matching the guest-vlan so it goes into the tunnel to Mobility Controller.
    The thing is : How to make it managed/intercepted by Clearpass captive portal ?
    It might be a dumb question but as soon as I configure this SSID as 'Employee' type, I can't specify any external captive portal.
    As far as I understannd I would have to setup this security SSID as WPA2 Enterprise, 802.1x and then setup to my CPPM ? But ... this guest vlan doesn't have a direct access to CPPM.
    And even though I can access from this guest-vlan to CPPM, as soon as I get an IP from DHCP (external server, DC), I'm not even intercepted by CP-Guest.
    I was wondering then how you guys handle your guest network ?
  • 3.  RE: IAP Clusters with dedicated SSID for tunneled GUEST
    Posted May 19, 2017 02:23 AM
    If you have F5 then you can use F5  (public or private ip/host name)  for clearpass guest captive portal, here you need to allow F5 ip address/DNS host name(Insted of clearpass)  in IAP guest ssid pre-auth role. To work this, You need to create appropriate VIP policy in F5 for Guest user vlan so guest will redirec clearpass captive portal page through F5 .
    Milind Y
  • 4.  RE: IAP Clusters with dedicated SSID for tunneled GUEST
    Posted May 22, 2017 03:00 PM
    Hello guys,
    I'm experiencing some weird issues and I would like to know what do you think about these issues.
    I did all my test as overrides on a VC.
    I deleted all overrides and planned to deploy the tested setup on the [main].
    I added the route into routing-table like : 172.16.33.0/24 (vlan 33, guest, dc) via 10.0.13.230 (mobility controller, dc).
    I've configured DHCP Centralized L2 Scope, Routing table, applied the configuration. Split tunnel enabled.
    I'm on the site 10.0.10.0/24, once the VPN get up, local connection to AP is lost. (tunnel established between 10.0.10.110 and 10.0.13.230), can't ping 10.0.10.110 anymore.
  • 5.  RE: IAP Clusters with dedicated SSID for tunneled GUEST
    Posted May 23, 2017 01:49 AM
    Hi ,
    I thought, you dont want to allow clearpass in guest network. Can you upload logical diagram of your network so it will be usful to understand your query.
    Milind Yashwantrao
  • 6.  RE: IAP Clusters with dedicated SSID for tunneled GUEST
    Posted May 24, 2017 08:10 PM
    Yeah sure.
    Here's the logical topology.
    Configuration is the same for both IAP (managed by Airwave).
    When I add Site1-IAP1 mac-address into whitelist-db rap on controller, the tunnel goes UP.
    And I loose connectivity from my CORP-PC to IAP.
    Same configuration on Site2-IAP1 and it works.
    I thought there might an unseen override, or a mismatch somewhere but no.
    I thought about split-tunnel, if it was enable or not.
    Both have :
    ip dhcp VL33-CL2
    server-type Centralized,L2
    server-vlan 33
    routing-profile
    route 172.16.33.0 255.255.255.0 10.0.13.230
    And the problem I have with guest is :
    Guest PC associates with SSID-Guest.
    SSID-Guest is a 'Guest' type SSID.
    Network-assigned : CL2-VL33 (vlan 33)
    Route: 172.16.33.0 is reached through 10.0.13.230
    There is a Aruba VPN between IAP (10.0.10.110, 10.0.20.110) and Controller (10.0.13.230).
    IP-Helper (redirecting a DHCP server on a VM in 10.0.13.x) is setup on mobility controller.
    I do get an IP address (172.16.33.X/24, Gateway: 172.16.33.254 etc.)
    SSID is setup to use captive portal located in 172.16.33.227 (which is virtual-ip/alias/NAT to Clearpass 10.0.13.227)
    I get intercepted by Clearpass Guest captive portal.
    I configured a sponsor confirmation, once confirmation is done.
    When I click on login, there is no authentication records on Clearpass Access tracker.
    I made it work only once, but then I got stuck in a redirecting loop.
    But that would be another problem, my main problem is ... How can I experience two different behaviors while I have the same deployed configuration.
  • 7.  RE: IAP Clusters with dedicated SSID for tunneled GUEST
    Posted Jun 13, 2017 07:43 PM
    I was wondering how could I debug this?
    Should I just open a case with Aruba?
  • 8.  RE: IAP Clusters with dedicated SSID for tunneled GUEST
    Posted Jun 14, 2017 06:23 AM
    Yes.
