IAP Configuration
This thread has been viewed 61 times
  • 1.  IAP Configuration
    Posted Oct 29, 2020 01:06 PM
    Hi everyone,
    Could any one help me with the steps, not any VRD or guide, to setup an IAP with the switch.
    What port configuration should be done in the switch. if the AP is currently working as an RAP and i want to make it an IAP for temporary time with initial configuration and provisioning steps.
    Thank you
    joxor
  • 2.  RE: IAP Configuration
    MVP EXPERT
    Posted Oct 30, 2020 04:10 AM
    For an IAP, the switch configuration would be defined as a trunk port. The untagged VLAN would be the IAPs management VLAN (where the IAP obtains an IP address for management) and the tagged VLANs would be your client VLANs.
    e.g
    VLAN10 = Untagged = IAP Mgmt
    VLAN20 = Tagged = Corporate WLAN
    VLAN30 = Tagged = Guest WLAN
    Craig Syme
  • 3.  RE: IAP Configuration
    Posted Oct 30, 2020 01:01 PM
    Thank you @Craig Syme
    Could you also help me with the steps for initial provision and configuration.
    1. Joxor
    Sayan Roy Chowdhury
  • 4.  RE: IAP Configuration
    MVP EXPERT
    Posted Oct 30, 2020 01:11 PM
    The provision of the switch port? That all depends on the switch model :) For example, a AOS-SW switch...
    interface 4
    name "ArubaIAP"
    tagged vlan 200
    untagged vlan 1
    exit
    Here's the initial provisioning info for setting up an IAP
    https://www.arubanetworks.com/techdocs/Instant_86_WebHelp/Content/instant-ug/prov-iap/setup-iap.htm
    Craig Syme
  • 5.  RE: IAP Configuration
    Posted Jan 17, 2021 10:00 AM
    Dear Craig Syme
    in case I need to use different VLANs, VLAN10 IAP mgmt and Virtual controller IP from the corporate subnet the below configuration will work or not.
    mohammad al-alami
  • 6.  RE: IAP Configuration
    Posted Jan 18, 2021 03:59 AM
    As Craig Syme mentioned, that was an example only.  Adjust the vlan ids to suit your environment.
    Michael Clarke (Aruba)
