IAP configure WPA2 TKIP
  • 1.  IAP configure WPA2 TKIP
    Posted Jan 09, 2015 11:15 AM
    can some one tell me if it is possible and how to configure one SSID on a IAP with WAP2 and TKIP?
    Thanks.
    LL
  • 2.  RE: IAP configure WPA2 TKIP
    Posted Jan 09, 2015 11:38 AM
    Yes
    From CLI:
    wlan ssid-profile <SSID NAME>
    disable
    index 1
    type employee
    essid <SSID NAME>
    wpa-passphrase <KEY>
    opmode wpa-psk-tkip,wpa2-psk-aes
    From GUI:
  • 3.  RE: IAP configure WPA2 TKIP
    Posted Jan 09, 2015 11:44 AM
    thanks for your reply, but my question is is it possible to configure WAP2-PSK-TKIP?
    LL
  • 4.  RE: IAP configure WPA2 TKIP
    Posted Jan 09, 2015 11:52 AM
    I apologize , I misread your post .
    But unfortunately it doesn't support that option.
  • 5.  RE: IAP configure WPA2 TKIP
    Posted Jan 09, 2015 12:04 PM
    Just use WPA-TKIP
  • 6.  RE: IAP configure WPA2 TKIP
    Posted Jan 09, 2015 01:13 PM
    Note, for the OP, that the spec for WPA2 doesn't allow for TKIP (WiFi Alliance) due to vulnerabilities within TKIP. As such, it's WPA-TKIP only. WPA2 requires AES.
