IAP - Controller GRE Tunnel issues
  • 1.  IAP - Controller GRE Tunnel issues
    Posted Jun 07, 2018 04:42 AM
    Morning all,
    I'm fairly new to configurating Aruba OS so on a learning curve.
    I'm trying to setup a pair of WLAN networks on a cluster of IAP-305s the corporate side works fine, but for guest I'm trying to GRE tunnel the traffic down to a DMZ controller in the data centre. I have tried to put together a diagram of what im trying to setup.
    But I cannot seem to get the IAP to esitmablish a GRE tunnel to the Controller.
    Thankyou in advance
    Luke
  • 2.  RE: IAP - Controller GRE Tunnel issues
    Posted Jun 07, 2018 06:33 AM
    I see your diagram.  Is there something not working?
  • 3.  RE: IAP - Controller GRE Tunnel issues
    Posted Jun 07, 2018 06:46 AM
    Thankyou for your message, sorry just relised I didnt put my issue in the text.
    Its the GRE tunnel I'm having issues with from the IAP towards the controller.
    IAP VC# show vpn config
    Concentrator
    Type                        Value
    VPN Primary Server
    VPN Backup Server
    VPN Preemption              disable
    VPN Fast Failover           disable
    VPN Hold Time               600
    VPN Monitor Pkt Send Freq   5
    VPN Monitor Pkt Lost Cnt    6
    VPN Ikepsk                  a7fb0e875c78851dcf3fc3c56c400cc0
    VPN Username
    VPN Password                1981c8660036e07909444708225f7d60
    GRE outside vpn             disable
    GRE Server                  10.182.95.146
    GRE IP Address              10.182.95.146
    GRE Type                    1
    GRE Per AP Tunnel           disable
    Reconnect User On Failover  disable
    Reconnect Time On Failover  60
    Routing Table
    Destination  Netmask  Gateway  Metric  Type  Flag
    Number of Route Entries   :0
    VPN Tunnel Profiles
    Profile  Primary  Backup  Preemption  Fast Failover  Hold Time  Monitor Pkt Send Freq  Monitor Pkt Lost Cnt  PSK  Username  Password  Group ID  Aggressive Mode
  • 4.  RE: IAP - Controller GRE Tunnel issues
    Posted Jun 07, 2018 06:58 AM
    On the DMZ controller, can you type "show datapath session table <ip address of instant VC>" to see if any traffic is coming from the Virtual Controller to the DMZ controller?
  • 5.  RE: IAP - Controller GRE Tunnel issues
    Posted Jun 07, 2018 07:03 AM
    (DMZ Controller) #show datapath session table 10.185.121.4
           Q - Real-Time Quality analysis
           E - Media Deep Inspect, G - media signal
      Source IP     Destination IP  Prot SPort DPort  Cntr Prio ToS Age Destination TAge Packets   Bytes      Flags
    (DMZ Controller) #
  • 6.  RE: IAP - Controller GRE Tunnel issues
    Posted Jun 07, 2018 07:18 AM
    That seems to suggest that none of the GRE traffic is getting through.  You might want to find out in your network what would be blocking that traffic.
  • 7.  RE: IAP - Controller GRE Tunnel issues
    MVP GURU
    Posted Aug 09, 2018 02:39 AM
    Why don't use IAP-VPN (-with IPSec), there is less network issue...
  • 8.  RE: IAP - Controller GRE Tunnel issues
    Posted Aug 10, 2018 04:06 AM
    Networks used GRE with the physciall controllers and wanted to do the same, ill propse it thankyou
  • 9.  RE: IAP - Controller GRE Tunnel issues
    Posted Oct 05, 2018 11:19 AM
    I am working on same kind of topology into our network, Is that any way I can get whole configuration of GRE tunnels on IAP and Controller. For testing purpose, I'm using IAP 325 and Controller 7205.
  • 10.  RE: IAP - Controller GRE Tunnel issues
    MVP GURU
    Posted Oct 07, 2018 12:20 PM
    What do you need ?
  • 11.  RE: IAP - Controller GRE Tunnel issues
    Posted Oct 08, 2018 09:04 AM
    I'm working with topology in which Aruba AP C325 connected with HP 2920 PoE+ switch on same LAN. We have a Aruba Controller 7205 in data center connected with FW. I want to create a GRE tunnel that contains traffic from AP to Controller. We need configuration of controller and AP.
  • 12.  RE: IAP - Controller GRE Tunnel issues
    MVP GURU
    Posted Oct 08, 2018 09:30 AM
    Why don't use IAP-VPN ? it is more easy like GRE for this
    Only need to specify the address IP of controller inside IAP-VPN Cluster.
