iap cp certificate upload stuck
  • 1.  iap cp certificate upload stuck
    Posted Sep 25, 2016 10:30 PM
    Thanks to, https://community.arubanetworks.com/t5/Wired-Networks/ArubaOS-Default-Certificate-Revocation-FAQ-Mobility-Access/ta-p/275815, I need to replace CP Server certificate.
    show log system shows nothing in IAP ....
  • 2.  RE: iap cp certificate upload stuck
    Posted Sep 25, 2016 11:41 PM
    The format is likely invalid. You need a PEM with public and private key plus CA certs. Did you follow the instructions in the FAQ?
  • 3.  RE: iap cp certificate upload stuck
    Posted Sep 25, 2016 11:58 PM
    Version of AOS.
    To be able to parse a wildcard.  As the cert is a wildcard.
    That was the issue.  It needs to be 6.5.0.0-4.3.0.0_######.. from Early Adoption.
