How can I configure a default gateway for the IAP on the CLI (from the console)?
Not tried it, but on my IAP, it would seem to be...
ip-address <address> <mask> <gateway> <dns-svr> <domain>
You do it at the hash prompt, not in configure mode. Should apply to interface br0 when done?
Please see if its helpful
I didnt know you HAD to put all the info in. I now need to point it to a controller to convert it - fingers crossed this can be done from the CLI.
Make sure the reg domain on the controller is the same as the IAP before doing that. And the controller needs to be 6.1.4 or later.
The command to do it is...
convert-aos-ap <CAP or RAP normally here> <controller-ip>
Managed to get this part from the documentation and its all worked - thanks for the helpful replies.
