IAP dhcp
  • 1.  IAP dhcp
    Posted Mar 01, 2012 04:18 AM
    I have some IAPs configured with three ssids.  One is for Guest and is using the IAP dhcp and the other two are using seperate vlan.
    When I plug the IAP into the network, I assume the port should be trunked?
    What ip address will the IAP get, I assume it will be the native vlan of that port, is that right?
  • 2.  RE: IAP dhcp
    Posted Mar 01, 2012 06:36 AM
    correct.
  • 3.  RE: IAP dhcp
    Posted Mar 01, 2012 06:41 AM
    Thanks Colin.
    :smileyhappy:
