IAP DHCP configuration Help
  • 1.  IAP DHCP configuration Help
    Posted Apr 27, 2017 06:45 AM
    I am setting a IAP with DHCP capablites. .
    My IAP Settings
    IP = 192.168.0.13, subnet = 255.255.255.0, Gateway = 192.168.0.1
    DNS = 8.8.8.8
    DHCP Server Setting in the IAP Under Local DHCP Scope Option
    Name = Demo, Type = Local,L2, Vlan = 1, Network = 192.168.2.0, Netmask = 255.255.255.240, Default router = 192.168.0.13,
    DNS = 8.8.8.8.
    I get the ip for the client device from the DHCP Scope but I am not able to reach the gateway.
    I also tried Local,L3 setup but still not luck
    Please help me to resovle it
    regards
    Jayakumar
  • 2.  RE: IAP DHCP configuration Help
    Posted Apr 27, 2017 07:03 AM
  • 3.  RE: IAP DHCP configuration Help
    Posted Apr 30, 2017 09:27 PM
    Hi JayaKumar,
    Are your IAP's on routable vlan ?
    Basically, the traffic that is destined to the Internet or local resources is source NATed using the physical IP address of the
    master AP.
    1. Are you able to reach out to the internet from IAP.
    # ping google.com
    2. Does the role assigned to the clients allow them to have access to internet ?
    If yes, then check the datapath session of the IAP using client IP
    #show datapath session | include <client IP>
