IAP DHCP Lease Time
  • 1.  IAP DHCP Lease Time
    Posted Mar 04, 2014 09:11 PM
    I need to set the lease time to at least 5 days and it's only letting me set it to 24 hours.  Should I be setting this somewhere else?
    Im running OS 6.3.1.2-4.0.0.3
  • 2.  RE: IAP DHCP Lease Time
    Posted Mar 04, 2014 09:23 PM
    Hello
    If you are using  a virtual controller assigment ip what you need to do to achive that is going in here
    System-->click advanced options--->dhcp
    In there you will be able to do that...
    Cheers
    Carlos
  • 3.  RE: IAP DHCP Lease Time
    Posted Mar 04, 2014 10:00 PM
    So I would  use just that lease time even though I am using DHCP under
    More-DHCP Server- Local DHCP Scopes
  • 4.  RE: IAP DHCP Lease Time
    Posted Mar 04, 2014 10:05 PM
    No.  You have to use the DHCP under system.
    I just saw you using a vlan 108
    Does that vlan 108 just exist in the virtual controller?
    If it does just exist in the virtual controller then instead of putting a vlan assigment on the configuration of the VAP use virtual controller assigment(that will use the dhcp server under system) and thats the one you need
    Now i dont know why Aruba Make it like that, both should have that option! :)
    Cheers
    Carlos
  • 5.  RE: IAP DHCP Lease Time
    Posted Mar 04, 2014 11:16 PM
    VLAN 108 also exists on the firewall.  The guest traffic is configured to go through this VLAN.
  • 6.  RE: IAP DHCP Lease Time
    Posted Mar 05, 2014 09:27 AM
    Well then the only option you got for now its putting the DHCP server on the firwall or on somwhere else, or the other option which i think its the best... nat the guest network and use the virtual controller ip assigment.
    It would be good to open a support case to ask the TAC if thats a bug or by design it is like it... because its weird that it just leave you 24 hours, on the DHCP local and it let you put under system dhcp the lease you want... i found that odd.
    Cheers
    Carlos
