last person joined: 7 hours ago
IAP DHCP Scopes
  • 1.  IAP DHCP Scopes
    Posted Nov 30, 2013 05:49 PM
    Hello's
    Is it possible to customize the size/range of IP addresses in the DHCP pool used by clients who are assigned an IP address by the Virtual Controller?
    In the cli guide ver 6.2.1.0-3.4 pg. 130, it is suggested that this is possible. However, neither the GUI or cli provide this option. Is the range specified by using a custom subnet mask as opposed to the default mask?
    Thanks much,
    Blue
  • 2.  RE: IAP DHCP Scopes
    Posted Nov 30, 2013 06:25 PM
    You won’t be able to exclude particular range of IP addresses (like 192.168.1.10 to 1.25).  You can only exclude the range as per below statement.
    Based on the size of the subnet, the IP addresses that come before or after the IP address value specified in this field are excluded.
    This is by design.
    Example:
    Subnet: 192.168.1.0 /24
    Excluded address: 192.168.1.20
    This will exclude addresses from 192.168.1.1 to 1.20.  Default Gateway should be 192.168.1.21
  • 3.  RE: IAP DHCP Scopes
    Posted Dec 01, 2013 05:55 PM
    Thanks for your response. It was not very clear however your description and I was unable to find in the documentation anything similar.
    Since the client wanted a small range of IP's as opposed to an entire network range due to how the application works, we defined a custom mask that reduced the number of available IP's
    thanks again for your time,
    Blue.
