IAP - Different models
  • 1.  IAP - Different models
    Posted Feb 23, 2014 01:50 AM
    Since the IAP 93 is limited to 16 APs per VC but other IAP models can support unlimited number of IAPs. Let's say I have a setup of IAPs that contains IAP93 and IAP105 which will be on the same VC, would it be limited to the 16 IAPs or unlimited number of IAPs ?
    Does the VC actually support different IAP models within the same cluster ?
  • 2.  RE: IAP - Different models
    Posted Feb 23, 2014 03:10 AM
    Hi
    Good morning. :smileywink:
    q: Let's say I have a setup of IAPs that contains IAP93 and IAP105 which will be on the same VC, would it be limited to the 16 IAPs or unlimited number of IAPs ?
    a: the iAP93 - will limit the VC to 16 units only - dosent matter which other higher models u got in the same VC.
    q: Does the VC actually support different IAP models within the same cluster ?
    a: Yes :)
    Have a gr8 day.
    Me
