IAP different vlan join in one VC
  • 1.  IAP different vlan join in one VC
    Posted May 23, 2014 09:56 AM
    HI all,
    I have 4 IAP.
    2 of the IAP get an IP with vlan 4 (192.168.4.x).
    the 2 others get an IP with vlan 5 (192.168.5.x).
    Set the IP virtual controller(VC) in Vlan 4.
    can the IAP with the vlan 5 join the VC or they need to be on the same vlan to join in the VC?
    thanks for your attention and advices before.
  • 2.  RE: IAP different vlan join in one VC
    Posted May 23, 2014 09:58 AM
    They all need to be in the same management Vlan  to join the same VC.
  • 3.  RE: IAP different vlan join in one VC
    Posted May 26, 2014 03:46 AM
    Ok Marcus,
    thanks for your info,
