IAP External Portal
  • 1.  IAP External Portal
    Posted Feb 21, 2016 12:36 PM
    Trying to get an external captive portal to work (Instant AP 6.4.4.3-4.2.2.0_53034).
    Tried to configure it like in https://arubapedia.arubanetworks.com/afp/index.php/External_Captive_Portal
    Also tried to use the url https://securelogin.arubanetworks.com/cgi-bin/login
    I would appreciate a working example of an external splash page with authentication text.
    Thank you for your help
    Johnny
  • 2.  RE: IAP External Portal
    Posted Feb 21, 2016 12:49 PM
    What part is not working? The redirect? The auth?
  • 3.  RE: IAP External Portal
    Posted Feb 21, 2016 01:11 PM
    Thank you for your quick response
    The redirect is working fine but the authentication is not working.
    I get no response from the VC
    wlan external-captive-portal froehlich.or.at
     server froehlich.or.at
     port 443
     url "/"
     auth-text "Accept"
     https
    <HTML>
    <HEAD>
    External Captive Portal Page <meta http-equiv="Content-Type" content="text/html; charset=GB2312"/>
    </HEAD>
    <BODY>
    <HTML>
    <form method="POST" ACTION="https://securelogin.arubanetworks.com/cgi-bin/login">
    <input type="hidden" name="user" value="guest">
    <input type="hidden" name="password" value="guest">
    <input type="submit" name="Accept" value="authenticate">
    </form>
    </HTML>
    </BODY>
    </HTML>
    wlan ssid-profile bstest
     enable
     index 1
     type guest
     essid bstest
     opmode opensystem
     max-authentication-failures 0
     auth-server InternalServer
     set-role-pre-auth preauth
     rf-band all
     captive-portal external profile froehlich.or.at
     dtim-period 1
     broadcast-filter arp
     dmo-channel-utilization-threshold 90
     local-probe-req-thresh 0
     max-clients-threshold 64
    user guest ed31476c3b980e2190ff0aedfc52fe51 portal
    wlan access-rule preauth
     index 6
     rule any any match any any any deny
  • 4.  RE: IAP External Portal
    Posted Feb 22, 2016 01:39 PM
    a working example was posted some time ago, a search for external captive portal should turn it up i hope.
  • 5.  RE: IAP External Portal
    Posted Feb 22, 2016 02:33 PM
    I was lucky finding the answer. I was missing a question mark at the end of my post command.
    So this works:
    <form method=POST action="http://securelogin.arubanetworks.com/cgi-bin/login?">
  • 6.  RE: IAP External Portal
    Posted Feb 22, 2016 10:53 PM
    can you share  little  more  about external  portals  actually i am also working on this  ...
    Did  you  designed  your  external portal  or  its a third party  software  ?
  • 7.  RE: IAP External Portal
    Posted Feb 23, 2016 01:47 AM
    Hello Kashan,
    the post comand is included in an external website done by an app designer. We are designing a guest wifi for chain of fitness gyms. normally I would like to use clearpass for this scenario, but in this case open authentication which neither Instant Aps nor clearpass can use was the option or a external captive portal hosted by the app designer was the option.
    If anyone ever achieved an open authentication with clearpass I would like to hear about it.
    -Johnny
  • 8.  RE: IAP External Portal
    Posted Feb 23, 2016 04:22 AM
    johannfroelich,
    When you say "Open Authentication", what do you mean?  ClearPass does support Open (just click accept), username and password or just a single passcode for authentication methods.
  • 9.  RE: IAP External Portal
    Posted Feb 23, 2016 04:28 AM
    Hi Colin,
    In this case I would require OAuth (like in https://en.wikipedia.org/wiki/OAuth).
    I know that clearpass can use SAML as SSO source. But this interface is not provided by this app designer.
    Thank you Johnny
