IAP External Splash Page
This thread has been viewed 16 times
  • 1.  IAP External Splash Page
    Posted Jun 08, 2021 04:49 PM
    In an IAP guest setup there is an option for an external splash page using "authentication text" to be returned.  What I am looking for is how to code that into a web page.  I have some basic HTML/CSS coding skills but I'm not making the connection with what the IAP is expecting in terms of "auth text" and how the web server is intended to provide it when clicking a button.
    Tyler West
  • 2.  RE: IAP External Splash Page
    Posted Jun 10, 2021 07:15 AM
    If you have access to Arubapedia (for Partners and Aruba employees), you could check this page with a section on the Authentication Text and an example.
    Note that the Authentication text only works on HTTP sites, as the HTML on the server is checked for the authentication text when the client retrieves it. It may be hard to find a non-HTTPS web service these days... and the user's browser may complain about an unencrypted connection. With HTTPS the AP cannot detect the HTML (as it is encrypted), so that is incompatible with Authentication Text. Don't hear this feature is used a lot, which may be because HTTP starts to slowly disappear.
  • 3.  RE: IAP External Splash Page
    Posted Jun 11, 2021 10:46 AM
    Thank you so much.  The examples led me right where I needed to go.
    Tyler West
  • 4.  RE: IAP External Splash Page
    Posted Jun 10, 2021 09:54 AM
    Hi Tyler,
    If you have HTML/CSS coding skills. Better use Radius Server like ClearPass which support Captive portal customization
    Dinusha Chandrasinghe - MVP | ACMP | ACSP |ACCA
    Network Engineer
    Plexus Global (Pvt) Ltd
    Colombo Sri Lanka
    +94717327420
