IAP Facebook Configuration link not showing
  • 1.  IAP Facebook Configuration link not showing
    Posted May 20, 2019 08:30 AM
    Dear all,
    I've been facing an issue with the Guest Facebook Login configuration on IAP 6.5.4.X.
    We have a cluster of 207 IAPs and they are reaching internet and resolving DNS queries as shown on the image below:IAP CLI PING URL.png
    The thing is that when i create an SSID with the Facebook login, the configuration link that should be present for me to indicate the page settings don't showup, as shown on the capture below:IAP FACEBOOK LOGIN NOT SHOWING.png
    Do you guys know what could be cause of this?
    Also i have a question:
    How many facebook login based SSIDs can we have on a IAP considering that each SSID will use a different facebook page? I couldn't find that info on User Guide, is there any docs that provide this info?
    Thank you!
  • 2.  RE: IAP Facebook Configuration link not showing
    Posted Jun 04, 2019 04:18 PM
    Guys, anyone here?
    Any news about this problem?
  • 3.  RE: IAP Facebook Configuration link not showing
    Posted Jun 04, 2019 04:38 PM
    Can you also send screenshot of the previous screens you saw in the SSID create/edit wizard?
  • 4.  RE: IAP Facebook Configuration link not showing
    Posted Jun 05, 2019 03:18 PM
    Hi Kitt, you mean on the VLAN tab?
  • 5.  RE: IAP Facebook Configuration link not showing
    Posted Jun 05, 2019 03:24 PM
    If you wanted to see the VLAN tab the configuration here is pretty straightforward but there it is
  • 6.  RE: IAP Facebook Configuration link not showing
    Posted Jun 05, 2019 03:29 PM
    I've gathered some new info about this issue. When i use AP Tech Support Dump and filter it using the word "facebook" the follow output is showed.
     captive-portal facebook
    Jun  5 18:28:40  awc[2427]: facebook_init: could not resolve 'graph.facebook.com'
    Jun  5 18:28:40  awc[2427]: facebook_reg_handler, 3363: facebook init failed
    Jun  5 18:21:58  cli[2430]: <341101> <WARN> |AP 9c:8c:d8:c6:63:ce@10.0.10.32 cli|  Execute command-captive-portal facebook.
    Jun  5 18:24:38  awc[2427]: facebook_init: could not resolve 'graph.facebook.com'
    Jun  5 18:24:38  awc[2427]: facebook_reg_handler, 3363: facebook init failed
    Jun  5 18:25:19  awc[2427]: facebook_init: could not resolve 'graph.facebook.com'
    Jun  5 18:25:19  awc[2427]: facebook_reg_handler, 3363: facebook init failed
    Jun  5 18:25:59  awc[2427]: facebook_init: could not resolve 'graph.facebook.com'
    Jun  5 18:25:59  awc[2427]: facebook_reg_handler, 3363: facebook init failed
    Jun  5 18:26:39  awc[2427]: facebook_init: could not resolve 'graph.facebook.com'
    Jun  5 18:26:39  awc[2427]: facebook_reg_handler, 3363: facebook init failed
    Jun  5 18:27:19  awc[2427]: facebook_init: could not resolve 'graph.facebook.com'
    Jun  5 18:27:19  awc[2427]: facebook_reg_handler, 3363: facebook init failed
    Jun  5 18:27:59  awc[2427]: facebook_reg_handler, 3363: facebook init failed
    "Teste FB"    "Teste FB"  0        guest     all   Facebook CP            none            Default VLAN   Enabled  -     Default  Yes
  • 7.  RE: IAP Facebook Configuration link not showing
    Posted Jul 21, 2019 07:27 AM
    I face with same issue, any body have solution for this please help me!!!
