IAP - Factory reset or clear startup-config via SSH
This thread has been viewed 26 times
  • 1.  IAP - Factory reset or clear startup-config via SSH
    Posted Aug 12, 2013 06:44 AM
    I would like to know if its possible to factory reset or remove the saved config of an IAP that's part of an existing cluster.
    I don't have physical access to the device and I would like it to wipe the config and re-join the cluster.
    Is this possible?
  • 2.  RE: IAP - Factory reset or clear startup-config via SSH
    Posted Aug 12, 2013 08:38 AM
    here u go:  :smileyvery-happy:
    GUI Method.
    • Click on "Maintenance" and go to the "Convert" tab.
    • In the dropdown for "Convert one or more APs to" choose "Standalone AP".
    • Pick the one you want.
    • This will gracefully exit the IAP from the VC cluster.
    Console method.
    • You need a the console cable that came in the IAP box.   (USB type A to type A).
    •  You need the USB console driver from the Aruba support site.
    • Connect the IAP to your favorite terminal program.
    • Log in with your configured ID/PW.
    • type "reload" and watch it reboot
    • right after the POST finishes, it gives you a 2 second timer to press enter to abort.  Press enter.
    • at the "apboot>" prompt type:
    • "purgeenv"
    • "clear os"
    • "save"
    • then reboot the AP.   this is functionally equivalent to pressing the reset button on the other units
