IAP Firmware
This thread has been viewed 113 times
  • 1.  IAP Firmware
    Posted Jan 30, 2017 02:52 PM
    Hi everyone.
    Somebody can give me the firmware 6.5.1.0-4.3.1.0_57768 for IAP (205/215) please.
    I need it
    Thank
  • 2.  RE: IAP Firmware
    Posted Jan 30, 2017 03:01 PM
    You can download the IAP software (and all other HPE Aruba software) via https://support.arubanetworks.com.
    Regards
  • 3.  RE: IAP Firmware
    Posted Jan 30, 2017 03:31 PM
    I know that, but i cant login in in the support portal.
  • 4.  RE: IAP Firmware
    Posted Jan 30, 2017 08:13 PM
    The latest version of early access code without a support contract that supports 205 and 215 and is here:  http://support.arubanetworks.com/LifetimeWarrantySoftware/tabid/121/DMXModule/661/EntryId/21998/Default.aspx
    6.4.4.4-4.2.3.2
  • 5.  RE: IAP Firmware
    Posted Jun 07, 2017 08:54 PM
    I have this problem. i have iap-205 and i extend my wifi network with iap207. but i cannot integrate existing system with firmware mismatch error. how to solve this problem guys?
  • 6.  RE: IAP Firmware
    Posted Jun 08, 2017 04:38 AM
    Hello TuRuu,
    If your cluster is built on only IAP-205 APs, you cannot automatically add the IAP-207 to the cluster. The IAP-207 needs to have the same software version as the IAP-205 APs before you add the AP to the cluster. The IAP-207 is using a different image (Vela) compared with the IAP-205 (Taurus).
    The best way is to boot the IAP-207 stand-alone. Upgrade the IAP to the same software version as the IAP-205 cluster and add it to the cluster. That should do the trick.
    In the future, you can add additional IAP-207 automatically. They will get their firmware pushed from the cluster. You can also update the firmware of both IAP's via the cluster.
  • 7.  RE: IAP Firmware
    Posted May 30, 2019 06:49 AM
    Great help thanks....
  • 8.  RE: IAP Firmware
    Posted Aug 20, 2019 05:23 PM
    Hi there,
    Appreciate if anyone could send me link to download image version 6.4.2.6-4.1.3.0_54915 (Orion) for IAP-105.
    Thanks a lot in advance.
    Kind regards,
    Junix
  • 9.  RE: IAP Firmware
    Posted Aug 20, 2019 05:32 PM
