IAP Firmware Issue
  • 1.  IAP Firmware Issue
    Posted Oct 10, 2015 03:48 AM
    Hi All,
    I need the Latest firmware for IAP model 103 its very urgent. if anyone is having please share asap.
    Thanks & Regards
    Sonu Tripathi
  • 2.  RE: IAP Firmware Issue
    Posted Oct 10, 2015 05:16 AM
    Hi All,
    Please help me if you have  AP Class  "Pegasus"  latest firmware plese share its very urgent.
    I need to upgrade the firmware beacuse its running on the firware version 6.4.0.2-4.1.0.0_44004 and in this version its not broadcasting the ssid.
    Please share
    Thanks & Regards
    Sonu Tripathi
  • 3.  RE: IAP Firmware Issue
  • 4.  RE: IAP Firmware Issue
    Posted Oct 10, 2015 07:38 AM
    Hi Please send me a valid downloadabe file. This file is not working
  • 5.  RE: IAP Firmware Issue
    Posted Oct 10, 2015 07:41 AM
    Those are the valid images. If you're having issues, contact Aruba TAC.
    Tim
  • 6.  RE: IAP Firmware Issue
    Posted Oct 10, 2015 02:47 PM
    Tim is correct but if it is not broadcasting an SSID, what regulatory domain have you chosen?
  • 7.  RE: IAP Firmware Issue
    Posted Oct 18, 2015 04:24 AM
    yes issue got resolved when i changed the country code as JAPAN (JP3) in other regularity domain it was not working...
    Thanks & Regards
    Sonu
