IAP firware upgrade
  • 1.  IAP firware upgrade
    Posted Aug 09, 2013 04:07 PM
    I began an IAP installation by booting one AP, upgrading the firmware to the latest version I saw (6.2.1.0-3.4.0.0_39086), creating two networks and testing same (one internal and one guest), and changing admin password.  I installed the AP in it's final location, so it was rebooted a couple of times following upgrade and configuration; all was well up to this point.
    I then put a second AP on the network expecting to simply plug in all additional APs to complete this installation.  The second AP is not being found or recognized by the master.  Both APs are on the same subnet and, in fact, on the same switch.  The second AP I am trying to join to the network has green indicators on power and ethernet, but red indicators on 11a/n and 11/b/g/n.
    I have 30 APs total to install and have tried two different APs in addition to the master; both additional APs are behaving the same.
    I will appreciate any comments or solutions!
  • 2.  RE: IAP firware upgrade
    Posted Aug 09, 2013 04:43 PM
    Are they all IAPs?
  • 3.  RE: IAP firware upgrade
    Posted Aug 09, 2013 05:09 PM
    Yes.
  • 4.  RE: IAP firware upgrade
    Posted Aug 09, 2013 06:09 PM
    How about the same model?
    92, 93, 104, 105, etc. share the same revision family (Orion)
    134 and 135 sare a different revision family (Cassiopeia)
    there are others for various models of RAP.
  • 5.  RE: IAP firware upgrade
    Posted Aug 09, 2013 08:11 PM
    Verify the following :
    - make sure those IAPs are able to get an IP address (check if you can ping those)
    - make sure that they are in the same country code
    - on the VC under support RUN the AP logs all
    - auto is enabled ?
  • 6.  RE: IAP firware upgrade
    Posted Aug 09, 2013 08:19 PM
    Please look for "show log system " which would give more info.
    Is the uplink switch tags the native vlan as well? Verify the uplink config and worth to take pcap to understand more about the communication.
  • 7.  RE: IAP firware upgrade
    Posted Aug 09, 2013 10:21 PM
    This can occur if:
    1. The VC and the new member are of different regulatory domains.  Ex.  -US and a "rest of world" version.
    2. If the version running on the VC is the latest version and it has not yet been posted to the cloud based upgrade server.  If this is the case the new member will be unable to upgrade to the version the VC is running and will be in the state you describe.
    Question for you:
    When you upgraded the VC did you do it manually by downloading v.3.4 to your PC from the TAC site then push it to the VC via the "browse" button?   If this is the case, a quick solution will be to bring up the member that you are having the problem with in its' own vlan so it becomes its' own VC.  Once up then upgrade the SW to v. 3.4.  Now you can move it to the other group.
  • 8.  RE: IAP firware upgrade
    Posted Aug 12, 2013 08:13 AM
    Thank you for all of the responses.  It will be a couple of days until I can get back to this and will respond with further develpments at that time.
  • 9.  RE: IAP firware upgrade
    Posted Aug 13, 2013 02:33 PM
    I appreciate the responses; here is my update.
    Given that I was suspicious that performing the firmware update prior to bringing any other APs online was the root of the problem, I disconnected the Master from the network and started over again with another access point, making all of the same configurations, but not updating the firmware.  All APs are currently up and stable.  Therefore, my conclusion is that there is some proper order to performing the firmware upgrade that I am unaware of.  BTW, I still have not updated the firmware even after bringing all APs online.
    The AP that I first used as Master and which has the more current firmware on it is on the shelf as a spare.  Having a spare was part of the plan, so this is not a problem for now.
    I still welcome any further comments.  Thanks again.
  • 10.  RE: IAP firware upgrade
    Posted Aug 30, 2013 08:41 AM
    funny I was having the same issue with my RAP-109, manually upgraded to 3.4. 2nd AP from a factory reset won't join.
    Same subnet, same vlan, same everything.
    It receives an IP address and is pingable.
    Nothing in show log debug.
    If I console into the AP and attempt to login, it will not let me.
    Eashton, you went back to 3.3 and it just worked fine for you??
