IAP FW6.4.4.4-4.2.3.1_54637 Problem
  • 1.  IAP FW6.4.4.4-4.2.3.1_54637 Problem
    Posted May 10, 2016 05:11 AM
    After installing IAP FW6.4.4.4-4.2.3.1_54637 we have major connection issues with Chromebooks. Chromebooks cannot connect to Wifi at all.
    Reverted back to 4.1.1.11 and all is fine.
  • 2.  RE: IAP FW6.4.4.4-4.2.3.1_54637 Problem
    Posted May 10, 2016 05:59 AM
    What model APs are you using?
    What kind of SSID are you broadcasting?
    Is it using encryption?
    Why did you ugrade?
  • 3.  RE: IAP FW6.4.4.4-4.2.3.1_54637 Problem
    Posted May 10, 2016 11:58 AM
    Model: 16x 105 and a 205
    SSID: "De Sluis"
    Encr: WPA2-PSK
    Reason to upgrade were the mails from Aruba Product Security Advisory ARUBA-PSA-2016-004
  • 4.  RE: IAP FW6.4.4.4-4.2.3.1_54637 Problem
    Posted May 11, 2016 12:43 AM
    4.1.3.0 is another good choice for 4.1.1 networks that need to beef up security.
