IAP GRE Through VPN To Controller
  • 1.  IAP GRE Through VPN To Controller
    Posted Oct 02, 2013 10:55 AM
    Hello All,
    I currently have controllers configured to create an IPSEC tunnel and then run a L2 GRE tunnel through that IPSEC back to a DMZ'ed controller.  I'd like to do the same for a Virtual Controller on an IAP cluster.  I currently have a VPN tunnel configured and it's established but am having some issues getting the L2 GRE portion created.  Is this accomplished through configuring a DHCP server in Centralized L2 mode?  I currently have that configured with the VLAN that exists on the DMZ'ed controller that has the VPN tunnel terminated referenced but the client never gets an IP address assigned.  I checked the logs on the DMZ'ed controller and saw these messages, not sure if it has any relevance:
    Oct 2 09:31:16 IAP manager Process[2435]: <342001> <ERRS> |IAP manager Pro| handle_iap_dpp_vlan_add: branch e441467e01143eae9ec0ca80f658e257864aabb51462eefea2 does not exist
    Oct 2 09:43:40 IAP manager Process[2435]: <342001> <ERRS> |IAP manager Pro| handle_iap_dpp_vlan_del: branch e441467e01143eae9ec0ca80f658e257864aabb51462eefea2 does not exist
    Oct 2 09:43:46 IAP manager Process[2435]: <342001> <ERRS> |IAP manager Pro| handle_iap_dpp_vlan_add: branch e441467e01143eae9ec0ca80f658e257864aabb51462eefea2 does not exist
    Anyone have any suggestions?
    Brian
  • 2.  RE: IAP GRE Through VPN To Controller
    Posted Jul 31, 2015 07:46 AM
    i have encountered the same problem this morning i have solved using this command on the controller
    #iap trusted-branch-db add mac-address <mac of IAP>.
    After i have used:
    #show iap trusted-branch-db
    And you can see the mac added with the previous command.
    I hope that this can help you too.
    Regards
    Andrea
  • 3.  RE: IAP GRE Through VPN To Controller
    Posted Aug 17, 2015 05:03 AM
    have you solved your issue?
    Best regards
    Andrea
