IAP Guest Account expiration
  • 1.  IAP Guest Account expiration
    Posted Aug 22, 2014 02:05 PM
    Is it not possible to set an expiration for internal guest accounts with an IAP deployment?
  • 2.  RE: IAP Guest Account expiration
    Posted Aug 22, 2014 02:12 PM
    No - this is not possible
  • 3.  RE: IAP Guest Account expiration
    Posted Aug 22, 2014 02:29 PM
    The closest you can get, without using ClearPass, would be to use the Reauth interval.   This would just force the user to re-authenticate periodically but the account would not age out.
