IAP Guest network route
  • 1.  IAP Guest network route
    Posted Sep 18, 2014 08:21 AM
    I have two incoming Internet connections connected to a Netscreen firewall (#1 and #2). I have IAP-115's with a guest network and controller-assigned IPs. I would like all traffic on the guest network to be directed to one connection (#2), while the employee SSID (which has network assigned DHCP) continues as normal (connection #1).
    So, the question is: is it possible to force all traffic on the guest SSID to a single IP as it's next hop router? That way, any guest traffic gets directed to port #2 on the firewall. Or is it possible to have all traffic from the guest SSID come from a single IP (but not the virtual controller address)?
  • 2.  RE: IAP Guest network route
    Posted Sep 18, 2014 08:49 AM
    It would probably be best to have your client L3s in your firewall and trunk down to the APs. Then you can control routing on your firewall.
